I was reading on misra website that for assigning 0 to unsigned variable, 'u' must be suffixed.
For example:
uint8_t my_cnt = 0U;
1. Does that even on declaring array I should use this.Like
uint8_t my_arr[10U];
2. Also while using switch cases like:
void func(uint8_t no) { switch(no) { case 1U: break; case 2U: break; } }
If yes then what if variable passed to switch is of int8_t type. In above example if
int8_t no;
Rule 10.6 (required): A "U" suffix shall be applied to all constants of unsigned type.
