Hi All,
I am new to LPC controllers. Earlier i have used ST MCU's. I have created a new project in keil uv5. added the example code from blinky for MCB2103 board.
The code is just a simple modified for reading some pins as inputs and then setting some pins as outputs.
Build is OK.
But if i simulate it with Keil simulator. the following error comes "Data Abort: ARM Instruction at 0000005CH, Memory Access at 20000000H"
I am not accessing this memory in my code. The error is disassembly under the __scatterload_copy: area.
Please help, i have no idea why this error is coming.
