GPIO interrupt won't trigger
I have set a pin on a Cortex M3 to act as an rising-edge triggered interrupt and it's not firing for some reason. What it should do is receive a 1Hz pulse, trigger an interrupt and start a 12.8Khz square wave.
I'm using uVision 5.
__main and EINT3_IRQHandler are defined in startup code created by the program, Keil uVision 5. The GPIO interrupts share the EINT3 interrupt vector with a different external interrupt. I figured it would only be a matter of activating the GPIO and EINT3 interrupts then putting the handler within the EINT3_IRQHandler label.
The GPIO interrupts are described on page 129 of this data sheet.
www.nxp.com/.../UM10360.pdf
I also tried to just set it to read the interrupt status by using
    check
        CMP [status_register], #1   ; Check interrupt status
        BEQ wave_gen                ; If triggered, start square wave
        BNE check                   ; else keep checking
and use that as a trigger but that didn't work either.
This is my code.
                AREA main, CODE, READONLY
                EXPORT __main
                EXPORT EINT3_IRQHandler
                ALIGN
        __main
                LDR     R1,=0x2009c000      ; Pointer to base of port 0
                LDR     R2,=0x00000001      ; To control pin 0 for square wave
                LDR     R3,=0x00000001      ; For XOR to invert pin 0
                STR     R2,[R1,#0x00]       ; Set pin 0 to output mode (base+0x00)
                STR     R2,[R1,#0x14]       ; Pin 0 HIGH
                LDR     R4,=780             ; Set up timer
                LDR     R5,=0x40028080      ; GPIO Rising Edge Interrupt
                LDR     R7,=0xE000E100      ; Set EINT3-enable register
                LDR     R6,=0x00000002      ; For pin 0:1
                STR     R6,[R5,#10]         ; Activate 0:1 as rising edge interrupt
                LDR     R6,=0x00200000      ; To enable ENINT3
                STR     R6,[R7]             ; Enables EINT3
                WFI
        wave_gen
                SUB     R4, #1              ; Decrement timer
                CMP     R4, #0              ; Compare to 0
                BNE     wave_gen            ; If !0, keep looping
                LDR     R4,=975             ; Reset timer
                EOR     R2,R3               ; Invert bits
                STR     R2,[R1,#0x14]       ; Invert pin
                MUL     R3,R3,R3            ; To waste cycles, ignore (1*1=1)
                MUL     R3,R3,R3
                B       wave_gen            ; Restart loop
        EINT3_IRQHandler
                B               wave_gen    ; Start square wave
                ALIGN
