Hello Sir,
I am working on USB host for HID class using LPC2468 controller . I am using USB Hostlite example as a base . I made this code compatible for both full speed and low speed hid device. Now i am trying to create USB Device instance for that i have structure declaration as shown in following code.
struct usb_device_instance { UWORD8 *p_USB_DeviceDescriptor; UWORD8 *p_USB_ConfigDescriptor; UWORD8 *p_USB_StringDescriptor; UWORD8 *p_HID_ReportDescriptor; UWORD8 bUSB_DeviceAddress; /* USB bus address */ UWORD8 bUSB_Configuration; /* current configuration number */ //UWORD16 wUSB_DeviceStatus; /* bits 15-3 = 0; bit(1) = Remote Wakeup; bit(0) = Self Powered */ /* bits 31-16: input endpoints; bits 15-0: output endpoints */ //UWORD32 fg_USB_EndPointMask; /* working endpoints for current configuration */ //UWORD32 fg_USB_EndPointHalt; /* HALTED working endpoints for current configuration */ UWORD8 ep0_bMaxPacketSize; /* maximum packet size declared in Device Descriptor */ UWORD8 bNumConfigurations; UWORD8 bNumInterfaces; /* number of interfaces for current configuration */ UWORD8 bMaxNumInterfaces; /* Maximum number of interfaces for all possible configurations */ UWORD8 bNumStrings; /* number of strings */ UWORD8 bNumReportDescriptors; /* number of report descriptors */ //UWORD8 *p_bEP0Buf; /* working buffer for Control Transfer ep0 */ UWORD8 *p_bAltSetting_perIFC; /* Alternate Setting No. per Interfaces for current configuration */ UWORD8 *p_bHID_Protocol; //UWORD8 *p_bHID_IdleTime; //UWORD8 *p_bHID_IdleCount; UWORD8 bIFCs_ready; struct usb_IFC_instance *p_IFCs; UWORD32 fg_queue_IFCs; /* bits 31-16: IFCs of IN transfer requests; bits 15-0: IFCs of Out (or Feature) transfer requests; */ //CB_USB_Rx_Handler *p_callback_Rx_handler; /* User's handler Function for output and feature reports */ //CB_USB_BufMapping *p_callback_bufMapping; struct HID_repDesc_info *p_subRepDescriptor; /* information block of report descriptors */ UWORD8 *p_head_RIDinfo; UWORD8 wSize_ConfigDescriptor; UWORD8 wSize_StringDescriptor; UWORD8 wSize_ReportDescriptor; };
I am facing a problem when i take a pointer of this type as shown below struct usb_device_instance *p_usbD ;
when I debug through the software i observe that this is taking address 0x00000000. I don,t want to use this address I have already used ram upto 0x4000F8D8. I just want to confirm that can there be a special address like TD buffer has special address 0x7FD00150.
One more thing i want to confirm that in case of mass storage class data comes in Userbuffer . In this case from which buffer we have to check data.
Thanks & Regars R.kumar
> struct usb_device_instance *p_usbD ; when I debug through the software i observe that this is taking address 0x00000000.
Maybe, p_usbD is declared but not initialized?
struct usb_device_instance usbD; struct usb_device_instance *p_usbD
p_usbD = &usbD;
As of the implementation of interrupt endpoint(s), see this thread. http://www.keil.com/forum/17034/
Also, for HID parser, see this post http://www.keil.com/forum/20246/
Tsuneo
