Dear All How can I force the compiler to not generate the "BX LR" for the return function. I also set the option --ARM_only(in compiler + assembler + linker) but this is not useful and I have this code at last in axf file. my target in Keil is set to ARM7TDMI (I can not set my target to ARM7 or any other target without Thumb) so what can we do to prevent generate "BX LR"?
while (1)...?
I do not understand your reply!
"but I want to solve it with the compiler options and not delete the return from the code!"
Why? Either way you must rebuild the code.
I don't think you can suppressed the generation of BX LR. Are you seriously suggesting that the compiler does not generate that instruction even if the programmer inserted a "return" at the end of the function, only because of a compiler switch?
What are you looking to have instead of the BX LR ?
Wrong view.
A function either return or it doesn't return.
A compiler switch will not help you with that.
If you write code that never returns, then the compiler optimizer _may_ decide to skip any return code. Just as a function that ends with a call to another function normally have the return code removed and the call converted to a jump.
Anyway - you either program in C/C++. Or you program in assembler. Directly when _you_ think that the generated assembler must look a certain way, _you_ have to switch to writing that assembler yourself. The goal with C/C++ is that the programmer should not be in control of generated machine code instructions.
Ok, we can have "MOV PC,LR" instead of "BX LD" or we can have "BL" , I want to have pure ARM instructions not ARM/Thumb instructions.
I do not mean to change the compiler or rewrite it!!, I only want to know how we can prevent the compiler to generate a ARM/Thumb code when we want it to produce the code for ARM_only target! return or not-return from a function is not my concern at all. I only want to tell the compiler not to generate the BX command. this is all the story!
"this is all the story!"
Why did you not say so from the beginning, them?! I am not sure you can do what you wish for.
why not? The BX is not ARM_only instruction so the compiler must not generate it when in ARM_only mode??!!
Check this out:
newsgroups.derkeiler.com/.../msg00031.html
There is likely to be plenty more if you were to consider looking!
Thanks, but how can I tell the linker to substitute the "BX LR" with "MOV PC,LR" ?
upload.wikimedia.org/.../300px-Paris_Tuileries_Garden_Facepalm_statue.jpg
Use assembler.
How can I use assembler options to do this?
infocenter.arm.com/.../index.jsp
Specifically: Note
You must use a BX lr instruction at the end of the ARM subroutine to return to the caller. You cannot use the MOV pc,lr instruction to return in this situation because it does not cause the required change of state.
Note that the linked document is describing calling ARM code from Thumb. So it is only relevant if the startup code (and the C RTL) is using Thumb mode.
What really is important is that running a program that interfaces a Thumb-mode CRTL really must be compiled to play nice with Thumb-mode code. Look at your map file for all your nice CRTL functions you use - they have odd or even address? Any veneers to access them?
Note that as I previously described , I do not have Thumb mode and want to have only ARM instructions in my final code
The ARM7TDMI supports the instruction BX LR when in ARM mode. Look at the ARM instruction summary (as opposed the the Thumb instruction summary) and you will see that it mentions BX{cond} Rn.
What exactly do you think your problem is? It is clearly not what your problem really is. I will not waste any more time on you. Goodbye.
