several interrupts
hi,
my code is too long so i put snapshot of my code
#include<..........>
main()
void down(void)//down
                        ES=0; //disable serial ISR
                        timer_flag=0;
                        ph_sensor_error();
                        motor_direction=ANTI_CLOCK_WISE;
                        while(ph_sensor_down==OFF && timer_flag==0)
                                motor_power=ON;
                        motor_power=OFF;
                        timer_flag=0;
                        ES=1; //enable serial ISR
void ph_sensor_error(void)
        TR0 = 1;                      /* Start Timer 1 Running */
/*** timer0 interrupt service routine ***/
void timer0_ISR (void) interrupt 1
        TR0 = 0;
        TF0 = 0;
        TH0 = 0x00;
        TL0 = 0x00;
        counter++;   // Increment the overflow count
        if(counter>=10)//0.71s
                        TR0 = 0;
                        TF0=0;
                        counter=0;
                        timer_flag=1;
        else
                TR0 = 1;
/*** serial interrupt ***/
void serial_ISR (void) interrupt 4
        unsigned char moh=0;
        if (RI == 1)
        RI = 0;
                moh=SBUF;
                if(SBUF==0x31)
                        down();
my problem is when i entered in serial_ISR and the SBUF=0x31 it mean the condition true,when i call down() function i can not from it enter to timer0_ISR never. how can i solve this problem?
  • My problem solved. I set priority for timer0_ISR higher than serial_ISR so in this case serial_ISR can be interrupted with timer0_ISR. I did it with this code
    [CODE]
    IPL0 = 0x02; //make serial interrupt lower priority than timer0 to be can interrupt
    IPH0 = 0x00; //serial ISR with timer0 ISR
    [/CODE]
    i used at89c51ed2.
    [CODE]
    [/CODE]
    i used at89c51ed2.
