Debug Hard fault -> LPC1317-64P
I want to debug hard fault in LPC1317-64P.
I took reference from below site:
support.code-red-tech.com/.../DebugHardFault
But code gives error
1. for asm Code:
source\main.c(12): warning: #1207-D: attribute "naked" ignored
source\main.c(20): error: #1113: Inline assembler not permitted when generating Thumb code
2. For C Code
source\main.c(65): error: #1113: Inline assembler not permitted when generating Thumb code
But code there is for LPCXpresso. How to use it in keil.
  • #pragma pack(push, 4)
    typedef struct
            uint32_t r0;
            uint32_t r1;
            uint32_t r2;
            uint32_t r3;
            uint32_t r12;
            uint32_t lr;
            uint32_t pc;
            uint32_t psr;
    } stacked_regs_t;
    #pragma pack(pop)
    // This is called from the HardFault_HandlerAsm with a pointer the Fault stack as the parameter.
    // We can then read the values from the stack and place them into local variables for ease of reading.
    void hard_fault_debug_print(stacked_regs_t* stack) // prints 8 regs saved on the stack and so on
            dprintf("\n\nHard fault:\n");
            dprintf("R0  : %#08lx\n", stack->r0);
            dprintf("R1  : %#08lx\n", stack->r1);
            dprintf("R2  : %#08lx\n", stack->r2);
            dprintf("R3  : %#08lx\n", stack->r3);
            dprintf("R12 : %#08lx\n", stack->r12);
            dprintf("LR  : %#08lx\n", stack->lr);
            dprintf("PC  : %#08lx\n", stack->pc);
            dprintf("PSR : %#08lx\n", stack->psr);
            dprintf("BFAR: %#08lx\n", *((volatile uint32_t*)0xE000ED38));
            dprintf("CFSR: %#08lx\n", *((volatile uint32_t*)0xE000ED28));
            dprintf("HFSR: %#08lx\n", *((volatile uint32_t*)0xE000ED2C));
            dprintf("DFSR: %#08lx\n", *((volatile uint32_t*)0xE000ED30));
            dprintf("AFSR: %#08lx\n", *((volatile uint32_t*)0xE000ED3C));
    // Alternative Hard Fault handler to help debug the reason for a fault.
    // To use, edit the vector table to reference this function in the HardFault vector
    // This code is suitable for Cortex-M3 and Cortex-M0 cores
    __irq __asm void HardFault_Handler(void) // __attribute__((naked))
            EXPORT  HardFault_Handler
            IMPORT  hard_fault_debug_print
            tst   lr, #(1<<2)
            ite   eq
            mrseq r0, msp                  ; Main Stack was used, put MSP in R0
            mrsne r0, psp                  ; Process Stack was used, put PSP in R0   and after: LDR R0,[R0, #24]   ; Get stacked PC from stack
            b     (hard_fault_debug_print)
            b     .
    typedef struct
            uint32_t r0;
            uint32_t r1;
            uint32_t r2;
            uint32_t r3;
            uint32_t r12;
            uint32_t lr;
            uint32_t pc;
            uint32_t psr;
    } stacked_regs_t;
    #pragma pack(pop)
            tst   lr, #(1<<2)
            ite   eq
            b     .
