Generation of PWM using External Interrupt and Timer on a scope
Hi All,
I have put up the following code to generate continuous PWM using External Interrupt and Timer on a scope. For some reason, I can't get any output. Can anybody please help me with this one...???
I use a C8051F330 microcontroller to achieve the purpose.
// Include Files
#include <compiler_defs.h>                           // Macro definitions for 8051 Compiler //
#include <C8051F336_defs.h>                  // SFR declarations //
// Global Constants
#define SYSCLK             24500000/12                  // Clock speed in Hz //
SBIT (SW1, SFR_P0, 7);                  // SW1==0 means switch depressed //
// Function Prototypes
void Oscillator_Init (void);            // Configure the system clock //
void Port_Init (void);                  // Configure the Crossbar and GPIO //
void Timer2_Init (int counts);          // Configure Timer2 //
void PCA_Init (void);                   // Configure PCA for PWM mode //
void Ext_Interrupt_Init (void);         // Configure External Interrupts (INT0) //
INTERRUPT_PROTO (INT0_ISR, INTERRUPT_INT0);
// MAIN Routine
void main (void)
   PCA0MD &= ~0x40;                    // Disable Watchdog timer //
   int RELOAD_VALUE = 0;
   Oscillator_Init();                  // Initialize the system clock //
   Port_Init ();                           // Initialize crossbar and GPIO //
   Timer2_Init(SYSCLK/100);// Initialize Timer2 to generate interrupts at a 20kHz rate//
   PCA_Init ();                 // Initialize PCA for PWM //
   Ext_Interrupt_Init();                // Initialize External Interrupts //
   EA = 1;
   while(1)                           // Infinite while loop waiting for an interrupt //
                 if(TF2H == 1)
                         if (RELOAD_VALUE<65535)
                                                TF2H = 0;
                                                PCA0CP0 = RELOAD_VALUE;
                                                RELOAD_VALUE ++;
                         else
                                                TF2H = 0;
                                                RELOAD_VALUE =0;
// Oscillator_Init
// This routine initializes the system clock to use the precision internal
// oscillator as its clock source.
        CLKSEL = 0x00;  // Clock Select. SYSCLK is derived from the Internal High Frequency Oscillator and scaled per IFCN bits in register OSCICN //
        OSCICN = 0x83;    // Internal H-F Oscillator enabled and SYSCLK derived from Internal H-F Oscillator divided by 1 //
// Port_Init
   XBR1      = 0x40;            // Enable crossbar and weak pull ups //
   P0SKIP    = 0x7F;                    // Skip unused pins on P0 and P1 //
   P1SKIP    = 0xFF;
// Timer2_Init
   TMR2CN  = 0x00;                      // Stop Timer2. Clear T2SPLIT.
                        // Use SYSCLK/12 as timebase, 16-bit auto-reload
   CKCON  |= 0x30;                    // Timer2 High and Low byte uses the SYSCLK //
   TMR2RL  = -counts;   // Initialize reload value
   TMR2    = 0xFFFF;       // Set to reload immediately
// PCA_Init
void PCA_Init(void)
        PCA0MD    = 0x00;   // PCA Counter/Timer Idle Control enabled, Watchdog timer disabled, Watchdog timer enable unlocked, Unused, System clock divided by 12, Disable CF Interrupt //
        PCA0CPM0  = 0x82;        // PWM 16, ECOM, TOG, PWM, ECCF bits set //
         PCA0PWM        &= ~0x80;
// Ext_Interrupt_Init
   TCON   = 0x01;                   // INT 0 is edge triggered //
   IT01CF = 0x07;           // INT0 active low; INT0 on P0.7 //
   EX0 = 1;                 // Enable INT0 interrupts //
// Interrupt Service Routines
INTERRUPT(INT0_ISR, INTERRUPT_INT0)
   TR2  = 1;            // Start Timer2 //
Many Thanks in advance.
