bit addressable area of LPC2368
Hello Sir,
I am using LPC2368 controller in my project My project have some 1-bit flag as shown in following code flag number 1 to 22 working properly means writing 0 or 1 has affect on that.
But when I write 1 value to flag there is no change in flag.when i declare flag number ,23 ,24 ,25 of 1 byte seperately instead of using in this structure they are working properly i just want to confirm that is there is any bit addressable area in LPC2368 I checked the memory map of my project i sae that genflag structure is stored at 0x40000128 address and it is taking 12 byte why it is taking 12 byte?
struct flag{
unsigned fill_start:1;  //1
unsigned pow_pap_feed:1; //2
unsigned fl_print_start:1;
unsigned fl_stop_print:1;
unsigned fl_pap_sensor:1;
unsigned fl_platen_out:1;
unsigned fl_cutr_acc_ON:1;
unsigned fl_const_speed:1;
unsigned fl_line_print:1;
unsigned fl_start_print:1;
unsigned fl_pf_only:1;
unsigned fl_start:1;
unsigned fl_mt_accer:1;
unsigned fl_mt_deaccer:1;
unsigned fl_phase_rev:1;
unsigned fl_half_cut:1;
unsigned fl_home_position;
unsigned paperout:2;
unsigned fl_tempabove_80:1;
unsigned fl_recive_enable:1;
unsigned fl_init:1;
unsigned fl_stop_receive:1;  //22
unsigned fl_ESC_command:1;//23
unsigned fl_GS_command:1;//24
unsigned receive_cmd_arg:1;//25
unsigned wait4chartimeout:1;//26
}genflag;
Thanks & Regards
Rohit
  • No, the LPC23xx chips don't have any bit-addressable memory, and I'm not sure why you think it should have.
    Look at Cortex chips if you want a processor that have a special hardware solution for overlaying bitmaps on top of integers. The ARM core don't have special bitmap instructions so the solution used is to have a large array of integers overlapping so each integer in the array maps to a single bit of an integer at a different memory region. That allows the processor core to perform register-wide reads/writes when updating individual bits - all handled by the memory controller logic.
    You have 16 1-bit variables followed by the four byte large unsigned fl_home_position;
    Because of align, you will get 2 byte padding so fl_home_position gets 4-byte-aligned.
    So 2 bytes of bit-data, 2 bytes fillers, 4 bytes fl_home_position. That makes 8 bytes.
    Then you continue with 10 more bits of data. Now you have reached 10 bytes.
    Because the structure internally requires 4-byte align, the compiler will make the struct padded to be a multiple of four bytes large. This is required in case you have an array of this struct. So the struct will consume 2 bytes more with padding.
    So in total - 12 bytes consumed.
    If your 32-bit variable fl_home_position is placed first, you would get an 8 byte large struct since your 16+10 = 26 bits of bit-addressable fields can fit in four bytes.
Reply Children
