Hi, I tried to work this problem through Segger, but I tried what they said and it still does not work, and Segger referred me to Keil. The following is what I posted on the Segger forum, and their reply. I still have this issue. Thank You.
GUI_PID_StoreState question/problem In a Keil RTX environment I have my own PID driver, for a touch screen. It correctly gets interrupts and correctly retrieves touch information. I want to convey this information to Emwin, so that I can interact with GUI buttons and other controls. In my PID driver, in the interrupt routine, I have the following statements:
GUI_PID_STATE pState;
pState.x = touch.x; pState.y = touch.y; pState.Pressed = touch.pen_state; pState.Layer = 0; GUI_PID_StoreState(&pState);
In a separate RTX task, I have displayed a dialog on the screen with a button. This displays correctly, and I am expecting a "clicked" type of event. The following code gets about 8 messages pertaining to the initial display of the dialog and button, but it never gets any other messages. I would expect WM_NOTIFICATION messages, but there are none. I made the dialog and the button the size of the entire screen, so I know I'm pressing it, and the coordinates in pState are in the button area.
static void _cbDialog(WM_MESSAGE * pMsg) { int Id, NCode;
switch (pMsg->MsgId) { case WM_NOTIFY_PARENT: Id = WM_GetId(pMsg->hWinSrc); NCode = pMsg->Data.v; switch(Id) { case ID_BUTTON_0: // Notifications sent by 'Button' switch(NCode) { case WM_NOTIFICATION_CLICKED: break; case WM_NOTIFICATION_RELEASED: break; } break; } break; default: WM_DefaultProc(pMsg); break; } }
In another RTX task, I call GUI_Exec() periodically, which is supposed to service any window callbacks. (I now have also tried this in the dialog task.)
My touch events/info never interact with my dialog/button. Why not? There are no sources for emwin, so I can't debug this.
Thank You, Chuck
Quote Report Edit SEGGER - Adrian Super Moderator
Date of registration: May 26th 2009 Posts: 151
2 Friday, November 16th 2012, 2:37am Hello,
This actually should work, but in order to trace the problem you can do the following: Try calling GUI_Exec() from the task which creates the dialogs. In case this works, I would like to ask you to send the (working and not working) code which shows this behavior to support@segger.com. In case this does not work, please contact Keil Support. They should be able to debug the code for you.
Best regards, Adrian
Quote Report
Hi, this works now. Apparently it was always working but without source code I had no way of tracing what was going on. The problem was one of coordinates and the use of mismatched LCD displays and touch screens during development. Because of the mismatch, the "active" area of the touch screen was only about 1/8" x 1/8" in the very corner of the touch screen and I never happened to touch that spot.
Ty for feedback.
