Hello Forum! I am working on a FRDM-KL25Z dev board and hopign to have it come up as a virtual com port on a windows machine and then interact with the incoming data inside the ARM. I didn't see a straightforward example of doing a VCOM port on this processor so I started out with the USB HID example for the tower system with the same processor (Keil\ARM\Boards\Freescale\XTWR-KL25Z48M\RL\USB\Device\HID) and then copied the usb_config.c and usbd_user_cdc.c from another example (Keil\ARM\Boards\Keil\MCBSTR9\RL\USB\Device\CDC). The project compiles, I load it on the target, and then I see the virtual com port on my system (after installing the driver). I have stripped out the code from usbd_user_cdc.c to remove UART functionality. The problem I am having is when I try to open the virtual com port on the windows side. I tried 9600 baud, which seemed to be the default rate in the demo. I tried Putty and RealTerm, both applications hang when I try to open the specific com port. I was wondering if you folks had an idea what I was doing wrong or how I can begin to troubleshoot this. I have debugging access and it seems that USB works enough to identify its self on my system. I also included the CM1 usb library. I added some relevant code below. (I verified usb_config.c with the wizard and it seems to make sense) Thank you in advance!
I had to put the files on pastebin to meet the 7000 character limit
usb_config.c: http://pastebin.com/4vtczSUB usbd_user_cdc.c: http://pastebin.com/RrSrH3ML usbd_MKL25Z4.c: http://pastebin.com/D9WGuqnD
These PC applications put a sequence of these requests when they open target COM port. - Get_Line_Coding - Set_Line_Coding - Set_Control_Line_State
Using a hardware bus analyzer, or a software sniffer, specify the request on which your firmware fails. It narrows down the existing range of bug on your source code.
A sniffer, which recognizes CDC, is preferable. For example,
USBlyzer - 33 days trial www.usblyzer.com/download.htm
Run USBlyzer, enable "Capture->Capture Hot-plugged" menu, and plug in your device. And then open the COM port using PC application. What kind of error do you see on the log?
Tsuneo
Hi Tsuneo, I was able to capture opening the VCOM port, please see the two images below and the details of endpoints as well in the attached pastebin. I will post the hot-plugged capture as well, however, I think the enumeration portion is fine. Thanks for looking into this.
http://pastebin.com/MPigvYeV http://i.imgur.com/80ry4.png http://i.imgur.com/YiMGS.png
