Hi, I am trying to compile a example code from Atmel, which was written for Atmel Studio IDE, GCC or IAR compilers, and getting the following error:
error: #59: function call is not allowed in a constant expression
This is an similar example of the code:
const sam_abc xy_settings = {function_yz(), 111, 250 };
- sam_abc is a struct - function_yz() is the function which causes the error
I am using µVision V4.54.0.0 (C Compiler: Armcc).
How could I solve this problem? Can someone please help me. Thanks in advance.
Jan
Does the sam_abc structure contain a function pointer member? If so then I would suggest that function_yz() should actually be function_yz (or &function_yx) so that the structure contains the addresses of the function rather than attempting to call it.
Yes, I very much suspect that is the case.
It might be a GCC extension - or it might be a mistake by the OP when he "just (sic?) changed the name"...
