Hi Folks I must be doing something stupid. Simple program, main.c has code
#include<reg51.h> #include"sevenSeg.h" void main (void) { while (1) sevenSegWriteDecDigit(8); return; }
sevenSeg.h, which was added to the projecy automatically after the first compile of main.c has code
extern void sevenSegWriteDecDigit(unsigned char decDigit);
sevenSeg.c has not been added to project but has code
#ifndef __REG51_H__ sfr P1 = 0x90; #endif // This function displays the given decDigit on the display. // If the number in decDigit is greater than 9 no segments are lit. void sevenSegWriteDecDigit(unsigned char decDigit) { if (decDigit > 9) { // If not a number between 0 and 9, inclusive ... P1 = 0x0F; // turn all segments off } else { P1 = decDigit; } return; }
And when I try to compile I get two linker warnings that suggest that the sevenSeg.c isnt being found...
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: _SEVENSEGWRITEDECDIGIT MODULE: main.obj (MAIN) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _SEVENSEGWRITEDECDIGIT MODULE: main.obj (MAIN) ADDRESS: 080FH
Im racking my brains as to how this can be?!?!
Just noticed in the project pane that the header is being added as sevenseg.h and not sevenSeg.h ... would that matter?
Should I be explicitly adding the sevenSeg.c to the project?
if _SEVENSEGWRITEDECDIGIT is in sevenSeg.c, yes
the 'automatic inclusion of code when .h is included' only apply to standard c library functions
Ah well that would defo fix it then :) Ta Erik
