I'm having trouble with reassigning a pointer to a structure. Given the 2 files, structure.h and structure.c listed below:
structures.h ------------
struct device_struct { unsigned char address; struct message_struct* message; struct device_struct* next; }; struct message_struct { unsigned char id; }; extern struct device_struct struct_0_dev;
structures.c ------------
#include "structures.h" struct device_struct struct_0_dev = {0}; struct device_struct struct_1_dev = {0}; struct message_struct msg0 = {0}; void init_structures(void){ struct_0_dev.address = 0; struct_0_dev.message = &msg0; struct_0_dev.next = &struct_1_dev; }
I'm having trouble creating a new pointer in network.c to a device_struct and copying the pointer from a struct_0_dev to the new pointer. If I initialize temp_device_struct in the same line, it works fine (see below):
Network.c ---------
#include "structures.h" void network_enumeration(void){ struct device_struct* temp_device_struct = &struct_0_dev; unsigned char temp = 0; }
However, if I try to do it in a separate line as seen below, the compiler throws a C141 syntax error near the unsigned char temp = 0; line.
#include "structures.h" void network_enumeration(void){ struct device_struct* temp_device_struct; temp_device_struct = &struct_0_dev; unsigned char temp = 0; }
