Sirs,
I am trying to compare a register value to a hex code value as shown below:
if(P0 == 0xAA) { P0 = 0x00; } else if(P0 == 0x00) { P0 = 0xAA; }
in my code, I have it declared as:
sfr P0 = 0x80;
and initialized as:
P0 = 0x00;
Currently, the value of P0 is 0x00. Unfortunately, it isn't entering the else if loop as I would expect (so my program isn't setting P0 to 0xAA). I'm guessing it's because I am handling a register value incorrectly or can't compare a register value to a hex code. I'm guessing it's probably a pretty simple fix or there is a better approach to this. Can you help me understand what I am doing incorrectly? Thanks!
It seems to be seeing P0 as 0xFF for some reason (even though it was initialized as 0x00 and seems to show it being equal to 0x00 when I hover over P0 in simulation mode (as shown at this link)
http://imgh.us/p0_issues.jpg
Any idea why it thinks it's equal to 0xFF?
P0 is a port, so if it is initialized to output you can write a value on the register, and you can read this value! If it is initialized to input you can read the value of the port (0xFF if not connected and weak pull-up resistors enabled).
P0 is a port, so if it is initialized to output '51 ports can not be "initialized to output"
"'51 ports can not be "initialized to output""
Dependong on what '51 we talk about. Classic design or some of the souped-up versions.
