I'm debugging an interrupt service routine. I simulate a CAN message and expect the simulator to generate a receive interrupt, but this doesn't happen. I also tried this on a Keil code example, but the result was the same, so I assume the problem isn't in my code. Here's what I did:
1) Load the project Keil\ARM\Boards\Keil\MCB2300\CAN\CAN.uvproj in the IDE. 2) Add the following code to CAN_Simulate.ini:
func void CAN_transmit(void) { CAN1ID = 0xC7; CAN1L = 7; CAN1B0 = 0x07; CAN1B1 = 0xD4; CAN1B2 = 0x0C; CAN1B3 = 0x1F; CAN1B4 = 0x0A; CAN1B5 = 0x01; CAN1B6 = 0x00; CAN1B7 = 0x00; CAN1IN = 1; } define button "Send CAN message", "CAN_transmit();"
3) Compile. 4) Set a breakpoint in CAN.c after the line:
if (CAN1->GSR & (1 << 0)) { /* CAN Controller #1 meassage is received */
5) Run. 6) Click on the "Send CAN message" button. 7) See a received message in the "CAN communication" window, but no receive interrupt is generated.
At the same time transmit interrupts do get generated. What am doing wrong?
You may be looking for the problem in the wrong piece of your setup.
That's not actually the simulator's job. The simulator generates simulated CAN messages. Whether or not those generate receive interrupts is for your code to decide. Receive interrupts for CAN have to be enabled, typically in several places, to get any.
Most likely you didn't actually enable CAN Rx interrupts successfully --- or maybe just not for that particular message ID, on that particular CAN node.
Then what about the Keil example I mentioned? Did they too not enable CAN Rx interrupts successfully? :)
In KEIL's CanDemo.c
It seems that only CAN-ID=33 will generate Rx Interrupt.
/*---------------------------------------------------------------------------- initialize CAN interface *----------------------------------------------------------------------------*/ void can_Init (void) { CAN_setup (1); /* setup CAN Controller #1 */ CAN_setup (2); /* setup CAN Controller #2 */ CAN_wrFilter (1, 33, STANDARD_FORMAT); /* Enable reception of messages */ CAN_start (1); /* start CAN Controller #2 */ CAN_start (2); /* start CAN Controller #2 */ CAN_waitReady (1); /* wait til tx mbx is empty */ CAN_waitReady (2); /* wait til tx mbx is empty */ } int main (void) { int i; #ifdef RT_AGENT RTA_Init(); /* Initialize Real-Time Agent */ #endif PINSEL10 = 0; /* Disable ETM interface, enable LEDs */ adc_Init (); /* initialise A/D converter */ LED_init (); /* Initialize the LEDs */ can_Init (); /* initialise CAN interface */ lcd_init(); /* Initialize the LCD */ lcd_clear(); /* Clear the LCD */ lcd_print ("MCB2300 CAN Demo"); /* Display string on LCD display */ set_cursor (0, 1); /* Set cursor position on LCD display */ lcd_print (" http://www.keil.com "); delay (0x10000); /* Wait wait a while */ CAN_TxMsg[1].id = 33; /* initialise message to send */ for (i = 0; i < 8; i++) CAN_TxMsg[0].data[i] = 0; CAN_TxMsg[1].len = 1; CAN_TxMsg[1].format = STANDARD_FORMAT; CAN_TxMsg[1].type = DATA_FRAME; while (1) { val_Tx = adc_Get (); /* TX value changes in any case */ if (CAN_TxRdy[1]) { /* tx message on CAN Controller #2 */ CAN_TxRdy[1] = 0; CAN_TxMsg[1].data[0] = val_Tx; /* data[0] field = ADC value */ CAN_wrMsg (2, &CAN_TxMsg[1]); /* transmit message */ } delay (10000); /* Wait a while to receive the message */ if (CAN_RxRdy[0]) { /* rc message on CAN Controller #1 */ CAN_RxRdy[0] = 0; val_Rx = CAN_RxMsg[0].data[0]; } val_display (); /* display TX and RX values */ } }
Thanks a million, John!
