I can not get through with ROM-based constants.
When I put a definition:
const char txtParcer_OK[] = "ok! this is sample message ...";
the compiler resides the message in RAM area. I need ROM area.
I use µVision V4.20.03.0 Tool Version Numbers: Toolchain: MDK-ARM Standard Version: 4.20 Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.1.0.644 Assembler: Armasm.Exe V4.1.0.644 Linker/Locator: ArmLink.Exe V4.1.0.644 Librarian: ArmAr.Exe V4.1.0.644 Hex Converter: FromElf.Exe V4.1.0.644 CPU DLL: SARMCM3.DLL V4.20 Dialog DLL: DARMCM1.DLL V1.7.0.0 Target DLL: Bin\Nu_Link.dll V1.18 Dialog DLL: TARMCM1.DLL V1.06
Best regards, Alex.
Are you compiling in C++ mode? I hear, in C++ the meaning of const is different from C. Could this be it?
Also, if this is a local variable, it will be allocated on the stack even in C.
Hi Mike!
No Mike, I am compiling in plain C mode.
Usually, if to put code or static qualifier in first place of constant definition, it works, but here - it does not.
As for local variable - I am not sure. The const is defined in the beginning of the module. Not inside any function. Is it local? Not? I think - it should not be local. May be, I should define it globally by putting extern definition in .* file? I just have tried - in vain.
Thank you for help, Alex.
Alex,
are you sure? I am too using Nuvoton's M0 with a lot of cons char's (fonts) and all is placed where it should be. What does the linker say?
- Dejan
Did you try
static const acText[]= "...";
This should definitely work.
Hi Dejan,
Am I sure? I look into .map file. It says, that all my consts ar placed in 0x20000.... area. RAM data. The only way to place it to ROM area is to give directive __attribute ((( etc.
Word code , or static , or ROM, or any one specific word does not work.
Plus, main problem is, that I can not add more constants now. The program fails to work. As I comment a block of constants - it works again properly.
So, I think, I am sure. I have tried all the ways I know to place the constant to where it must be - so far all in vain.
Alex.
Hi b t.
Yes, I have tried all the ways. And this - too.
I have read posts for C166, for C51 - everywhere it works, but not for Keil uVision, it seems.
Impossible, in my code it works with "const char". But I use CPP compiler. But anyway should be no problem.
If I define const char acText[]= "Hallo"; , and then look at the variable acText in the watch window, it is defined at address 0x08006678, which is clearly a code address (uVision 4.60 - ARMCC 5.0 - STM32F4).
PS: Perhaps you have some very strange project settings. Best try it first in some fresh Blinky example directly from the Keil boards folder.
Thanks! I will try. As for the project settings - it is a copy of Nuvoton's sample projects' ones. I just have copied all the settings, one by one, and whole project file.
I am also very surprised, and think, that there is some small error somewhere in my files, so it worth to try new project. Just one string.
Thank you b t.
I have made the project up again from the very ground, and, by means of one-by-one .h files exclusion, found a definition in old&borrowed (Microchip C32) file:
#define const
So, when I comment it, everything works as it must.
Thank you folks. Thank you all. Best regards! Alex.
Strange that the compiler does not give a warning in such a case. It would be generally nice, if the compiler would produce some more warnings .... (empty code, ambiguous operator order).
Not at all!
It just means that the 'const' keyword was effectively stripped from the source code by the preprocessor. Since 'const' was purely optional in all the cases tried, there was nothing to warn about!
eg,
just becomes
and
static acText[]= "...";
BTW: There is nothing in the 'C' language definition that requires the compiler to put const items into read-only memory...
Yes. Stupid error, but that is it.
Thank you for the advice.
