I can not get through with ROM-based constants.
When I put a definition:
const char txtParcer_OK[] = "ok! this is sample message ...";
the compiler resides the message in RAM area. I need ROM area.
I use µVision V4.20.03.0 Tool Version Numbers: Toolchain: MDK-ARM Standard Version: 4.20 Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.1.0.644 Assembler: Armasm.Exe V4.1.0.644 Linker/Locator: ArmLink.Exe V4.1.0.644 Librarian: ArmAr.Exe V4.1.0.644 Hex Converter: FromElf.Exe V4.1.0.644 CPU DLL: SARMCM3.DLL V4.20 Dialog DLL: DARMCM1.DLL V1.7.0.0 Target DLL: Bin\Nu_Link.dll V1.18 Dialog DLL: TARMCM1.DLL V1.06
Best regards, Alex.
Are you compiling in C++ mode? I hear, in C++ the meaning of const is different from C. Could this be it?
Also, if this is a local variable, it will be allocated on the stack even in C.
