Dear all, The linker gives following error:
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT: ?DT?TIMER0_ISR?TIMER LENGTH: 0002H
I have a global buffer. If i declare it idata then the linker does not give any error. But the sprintf function gives garbage values. I am unable to understand the problem.
The following is the piece of code:
dtptr = &buff; strlen = sprintf(dtptr, "%d", PrbTemperature*1000); UART_TxArray(dtptr, strlen);
PrbTemperature is a float. dtptr, buff[7] and strlen are unsigned char.
kindly assist.
strlen() is a function available in the C standard library - are you saying that you have added own variables with same name?
Next thing - why do you have a float? You sure you really need a float to handle that temperature? Have you considered fixed point integers? That removes the need for linking in floating point support.
Another thing - you do &buff. You realize that the name buff itself represents the address of the first element of the buff[] array.
Have you verified that sprintf() gives your expected printout if you throw away some code/data so you don't have to change that buffer to idata? By the way - is it buff[] that you change to idata?
this is what i see on my terminal: Input Set-point Temperature 20201 ëGAÈ20264 îGAï20298 ðGB 20309 ïGB 20336 ðGB20176 óGB'19968 òGB219977 òGB>20239 õGBN20425 õGBT20433 öGBZ20447 õGBi20443 õGBr20464 ùGB€20443 ùGBˆ20165 úGB"20087 ùGBŸ20260 úGB«20542 ûGB®20572 ûGB¸20549 üGB¿20565 ûGBÅ20585 üGBÌ20579 ýGB×20342 þGBä20220 ÿGBê20275 20597 20702
The numbers are correctly displayed except that they are prefixed with some garbage values which i am unaware of how they creep in. and this is the change made in the code:
strlen = sprintf(dtptr, "%d", (uint16_t)(PrbTemperature*1000));
1. strlen is a variable that i have declared in my function. 2. I think float is required. or may be i can manipulate temperature by multiplying it with 1000 or 100. (other way round which i can think of, but dnt want to use. I am not confident about its working for all values of temperature) 3. I wrote &buff just because i want the compiler to know that i am giving the address of an array and not a variable (foolishness) 4. ya, i am defining buff as idata.
regards, Dhaval
ya. the values returned from the sprintf in the buffer are correct (not garbage).
even after modifying to this, i get garbage the values as seen on terminal. the values are given in the next post
fixing it with IDATA only works if that leaves enough stack You, probably, have stack overflow
char buff[] = "1234567"; char buff[7]; char buff[] = {1, 2, 3, 4, 5, 6, 7};
They all have in common that buff already is a const pointer to the buffer. You're passing a pointer to a pointer to sprintf, don't.
Not really. buff "is" not a pointer --- it's an array. It just automatically turns into a pointer in most of its usages.
No, he isn't. He's passing a pointer to an array. Because appling the address-of operator '&' is actually one of the exceptions to the above "most of" rule.
But you're still correct that &buff is not what should be passed to sprintf() --- even though it would usually work anyway. If you get a warning from your tools when you do this, you should consider that a good thing.
The Right Way(no TM) to do this is one of
sprintf(buff, ...); sprintf(&buff[0], ...); sprintf(&(buff[0]), ...);
These are all exactly equivalent, so most experienced C programmers will use the first form simply because it's shorter. But you'll find the other two forms quite frequently, too.
I do the #2 when I want to be explicit. Else I use the #1.
But I don't like type defines that are arrays - normally hide inside a struct to make the data a real black-box and avoid the array/pointer duality.
