Dear all, The linker gives following error:
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT: ?DT?TIMER0_ISR?TIMER LENGTH: 0002H
I have a global buffer. If i declare it idata then the linker does not give any error. But the sprintf function gives garbage values. I am unable to understand the problem.
The following is the piece of code:
dtptr = &buff; strlen = sprintf(dtptr, "%d", PrbTemperature*1000); UART_TxArray(dtptr, strlen);
PrbTemperature is a float. dtptr, buff[7] and strlen are unsigned char.
kindly assist.
