I'm sure I have seen / read something about this before, but I cannot now find that source.
I have added a variable to the Memory Window in uVision, "MyBuffer" for example. How do I specify IN THE MEMORY WINDOW an offset to that variable? For instance if 'MyBuffer' is a block of memory allocated to hold 1024 16bit values, and I am interested in watching the Memory location of the 512th (as well as the memory either side of it, so a 'Watch Window' will not suffice), how do I specify it? I vaguely remembered something along the lines of;
MyBuffer+0x200
but the Memory window does not accept that as in input, (the memory window goes blank, and I receive the error tone).
What is the correct format for this?
Thanks.
