init_TcpNet not working for RTX MCB1800 eval board
Hi, All
I tried to use http web service on MCB1800 eval board with RTX multi-tasking configuration, and found that init_TcpNet() never return if I call it in a task, the following is my code which I followed rtx example codehttp://www.keil.com/support/man/docs/rlarm/rlarm_tn_using_withkernel.htm
I set breakpoints on init_TcpNet and it never returns, if I call it on main(), it worked.
Any help will be appreciated. Thanks!
__task void tcp_tick (void) {
  os_itv_set (10);
  while (1) {
    os_itv_wait ();
    /* Timer tick every 1000 ms */
    timer_tick ();
__task void tcp_main (void) {
  while (1) {
    main_TcpNet ();
    os_tsk_pass ();
__task void Httptcp_init (void) {
  //system_init ();
  init_TcpNet ();
  os_tsk_create (tcp_tick, 2);
  os_tsk_create_user (tcp_main, 1, Task1_Stack, sizeof(Task1_Stack));
  /* Init done, terminate this task. */
  os_tsk_delete_self ();
int main (void) {
  os_sys_init (Httptcp_init);
