Recursive Call Warning? Why?
please can someone try this little code snippet with the C51 compiler and tell me why I am getting a "Linker Warning L13: Recursive Call to Segment Foo1, Caller: Foo2"
void foo1(void);
void foo2(void);
void (*function_pointer)(void) = &foo1;
void set_function(void(*p_function_pointer)(void))
  function_pointer = p_function_pointer;
void execute(void)
  (*function_pointer)();
void foo1(void)
  set_function(&foo2);
void foo2(void)
  bit Linker_Warning_Comes_With_Definition_Of_This_Bit;
  set_function(&foo1);
void main()
   execute();
  • Or a little bit shorter:
    void foo1(void);
    void foo2(void);
    void foo1(void)
      function_pointer = &foo2;
    void foo2(void)
      //linker warning comes with definition of this variable
      //Without this variable or if the variable is static, no warning occurs
      char var;
      function_pointer =&foo1;
    void main()
    Output is:
    Build target 'Target 1'
    compiling main.c...
    MAIN.C(17): warning C280: 'var': unreferenced local variable
    linking...
    *** WARNING L13: RECURSIVE CALL TO SEGMENT
        SEGMENT: ?PR?FOO1?MAIN
        CALLER:  ?PR?FOO2?MAIN
    Program Size: data=13.0 xdata=0 code=182
    "function_pointer_test" - 0 Error(s), 2 Warning(s).
    void foo1(void);
    void foo2(void);
    void foo1(void)
    void foo2(void)
      char var;
    void main()
    Output is:
    compiling main.c...
    linking...
