IData Declaration
Hello everyone,
I am using an 8051W device with uVision V4.02, working with an external C Tester and it's not recognizing the terms "idata" or "xdata". While I can create workarounds to this (ie make a specific compilation without these included), I'm trying to find a way to do this correctly.
When I searched through all the include files, the closest I can find to any references to IData is a line in my ISD51.H file that says:
#define RAMSIZE 0x100 // default is 0x100 => 256 bytes IDATA RAM
Unfortunately, this doesn't really declare it in a way that would be understandable to a universal C checker. I'm guessing the declaration of IData is something specific to the framework of Keil (though I could be wrong).
Does anyone know how to get the declaration of idata in universal terms that I might be able to place into the C tester that might declare what IData is in terms an external tester might recognize? (example: if I had a special variable, say, slong32 that one compiler recognized but the tester did not, I could add "typedef signed long slong32" and it would resolve the issue).
It's possible I just need to create a workaround but I thought you guys are the experts and might be able to point me the right direction.
I apologize if I left out any important information in order to answer this question. If I missed anything, please let me know and I'll try and find that information. Thanks!
