Hello everyone, I am using om11032 board which uses lpc1768. I am using pwm channel on port 2. When pwm runs no problem occurs but sometimes I try to stop all pwms but p2.0 p2.1....etc all get high and pwm does not stop. The code is given below. What may be the possible problem and its solution
/**************************************************************************** * $Id:: pwm.c 5748 2010-11-30 23:48:37Z usb00423 $ * Project: NXP LPC17xx PWM example * * Description: * This file contains PWM code example which include PWM initialization, * PWM interrupt handler, and APIs for PWM access. * **************************************************************************** * Software that is described herein is for illustrative purposes only * which provides customers with programming information regarding the * products. This software is supplied "AS IS" without any warranties. * NXP Semiconductors assumes no responsibility or liability for the * use of the software, conveys no license or title under any patent, * copyright, or mask work right to the product. NXP Semiconductors * reserves the right to make changes in the software without * notification. NXP Semiconductors also make no representation or * warranty that such application will be suitable for the specified * use without further testing or modification. ****************************************************************************/ #include "lpc17xx.h" #include "type.h" #include "pwm.h" volatile uint32_t match_counter0, match_counter1; /****************************************************************************** ** Function name: PWM1_IRQHandler ** ** Descriptions: PWM1 interrupt handler ** For now, it only deals with PWM1 match 0 ** ** parameters: None ** Returned value: None ** ******************************************************************************/ void PWM1_IRQHandler (void) { uint32_t regVal; regVal = LPC_PWM1->IR; if ( regVal & MR0_INT ) { match_counter1++; } LPC_PWM1->IR |= regVal; /* clear interrupt flag on match 0 */ return; } /****************************************************************************** ** Function name: PWM_Init ** ** Descriptions: PWM initialization, setup all GPIOs to PWM0~6, ** reset counter, all latches are enabled, interrupt ** on PWMMR0, install PWM interrupt to the VIC table. ** ** parameters: ChannelNum, Duty cycle ** Returned value: true or fase, if VIC table is full, return false ** ******************************************************************************/ uint32_t PWM_Init( uint32_t ChannelNum, uint32_t cycle ) { if ( ChannelNum == 1 ) { match_counter1 = 0; LPC_PINCON->PINSEL4 = 0x00001555; /* set GPIOs for all PWM pins on PWM */ LPC_PWM1->TCR = TCR_RESET; /* Counter Reset */ LPC_PWM1->PR = 0x00; /* count frequency:Fpclk */ LPC_PWM1->MCR = PWMMR0I; /* interrupt on PWMMR0, reset on PWMMR0, reset TC if PWM matches */ LPC_PWM1->MR0 = cycle; /* set PWM cycle */ LPC_PWM1->MR1 = cycle * 5/6; LPC_PWM1->MR2 = cycle * 2/3; LPC_PWM1->MR3 = cycle * 1/2; LPC_PWM1->MR4 = cycle * 1/3; LPC_PWM1->MR5 = cycle * 1/6; LPC_PWM1->MR6 = 0; /* all PWM latch enabled */ LPC_PWM1->LER = LER0_EN | LER1_EN | LER2_EN | LER3_EN | LER4_EN | LER5_EN | LER6_EN; } else { return ( FALSE ); /* Unknown channel number */ } NVIC_EnableIRQ(PWM1_IRQn); return (TRUE); } /****************************************************************************** ** Function name: PWM_Set ** ** Descriptions: PWM cycle setup ** ** parameters: Channel number, PWM cycle, and offset ** Returned value: None ** ******************************************************************************/ void PWM_Set( uint32_t ChannelNum, uint32_t cycle, uint32_t offset,double duty_cyc) { if ( ChannelNum == 1 ) { LPC_PWM1->MR0 = cycle; /* set PWM cycle */ LPC_PWM1->MR1 = cycle * 1/3 +offset; LPC_PWM1->MR2 = cycle * 1/3 +offset; LPC_PWM1->MR3 = cycle * 1/2 +offset; LPC_PWM1->MR4 = cycle * 1/3 +offset; LPC_PWM1->MR5 = cycle * 1/6 +offset; LPC_PWM1->MR6 = offset; /* The LER will be cleared when the Match 0 takes place, in order to load and execute the new value of match registers, all the PWMLERs need to reloaded. all PWM latch enabled */ LPC_PWM1->LER = LER0_EN | LER1_EN | LER2_EN | LER3_EN | LER4_EN | LER5_EN | LER6_EN; } return; } /****************************************************************************** ** Function name: PWM_Start ** ** Descriptions: Enable PWM by setting the PCR, PTCR registers ** ** parameters: channel number ** Returned value: None ** ******************************************************************************/ void PWM_Start( uint32_t channelNum ) { if ( channelNum == 1 ) { /* All single edge, all enable */ LPC_PWM1->PCR = PWMENA1 | PWMENA2 | PWMENA3 | PWMENA4 | PWMENA5 | PWMENA6; LPC_PWM1->TCR = TCR_CNT_EN | TCR_PWM_EN; /* counter enable, PWM enable */ } return; } /****************************************************************************** ** Function name: PWM_Stop ** ** Descriptions: Stop all PWM channels ** ** parameters: channel number ** Returned value: None ** ******************************************************************************/ void PWM_Stop( uint32_t channelNum ) { if ( channelNum == 1 ) { LPC_PWM1->PCR = 0; LPC_PWM1->TCR = 0x00; /* Stop all PWMs */ } return; }
I don't understand what that means, care to diagram?
The purpose of using pwm in my project to control a bldc motor speed. Pwms coming from prt p2.0 p2.1 and p2.2 connected to a low pass filter so I can get pure dc in high freq. The system works fine for a while. I can start the motor adjust the speed and stop the motor. But a strange thing occurs at some occasions. In some cases when I try to stop motor which I stop the pwm,pwm ports give me 3.3v. Then when I start pwm pulses again the problem disappears for a while then appears again. do you have any idea why this problem occurs. I have tested the program on keil om11032 board and also my own circuit. All the same. What kind of diagram should I supply. Kind Regards
The simplest solution might be to reconfigure the PWM pins as GPIO when you turn off the PWM functionality and have the GPIO pins pre-configured as output pins driven low. Then you will be sure that your pins are at close to 0V when you do not run the PWM functionality.
Thanks for your help,problem solved.
