pwm problem
Hello everyone,
I am using om11032 board which uses lpc1768. I am using pwm channel on port 2. When pwm runs no problem occurs but sometimes I try to stop all pwms but p2.0 p2.1....etc all get high and pwm does not stop. The code is given below. What may be the possible problem and its solution
 *   $Id:: pwm.c 5748 2010-11-30 23:48:37Z usb00423                         $
 *   Project: NXP LPC17xx PWM example
 *   Description:
 *     This file contains PWM code example which include PWM initialization,
 *     PWM interrupt handler, and APIs for PWM access.
 * Software that is described herein is for illustrative purposes only
 * which provides customers with programming information regarding the
 * products. This software is supplied "AS IS" without any warranties.
 * NXP Semiconductors assumes no responsibility or liability for the
 * use of the software, conveys no license or title under any patent,
 * copyright, or mask work right to the product. NXP Semiconductors
 * reserves the right to make changes in the software without
 * notification. NXP Semiconductors also make no representation or
 * warranty that such application will be suitable for the specified
 * use without further testing or modification.
#include "lpc17xx.h"
#include "type.h"
#include "pwm.h"
volatile uint32_t match_counter0, match_counter1;
** Function name:               PWM1_IRQHandler
** Descriptions:                PWM1 interrupt handler
**                                              For now, it only deals with PWM1 match 0
** parameters:                  None
** Returned value:              None
void PWM1_IRQHandler (void)
  uint32_t regVal;
  regVal = LPC_PWM1->IR;
  if ( regVal & MR0_INT )
        match_counter1++;
  LPC_PWM1->IR |= regVal;            /* clear interrupt flag on match 0 */
  return;
** Function name:               PWM_Init
** Descriptions:                PWM initialization, setup all GPIOs to PWM0~6,
**                                              reset counter, all latches are enabled, interrupt
**                                              on PWMMR0, install PWM interrupt to the VIC table.
** parameters:                  ChannelNum, Duty cycle
** Returned value:              true or fase, if VIC table is full, return false
uint32_t PWM_Init( uint32_t ChannelNum, uint32_t cycle )
  if ( ChannelNum == 1 )
        match_counter1 = 0;
        LPC_PINCON->PINSEL4 = 0x00001555;    /* set GPIOs for all PWM pins on PWM */
        LPC_PWM1->TCR = TCR_RESET;   /* Counter Reset */
        LPC_PWM1->PR = 0x00;         /* count frequency:Fpclk */
        LPC_PWM1->MCR = PWMMR0I;     /* interrupt on PWMMR0, reset on PWMMR0, reset
        TC if PWM matches */
        LPC_PWM1->MR0 = cycle;               /* set PWM cycle */
        LPC_PWM1->MR1 = cycle * 5/6;
        LPC_PWM1->MR2 = cycle * 2/3;
        LPC_PWM1->MR3 = cycle * 1/2;
        LPC_PWM1->MR4 = cycle * 1/3;
        LPC_PWM1->MR5 = cycle * 1/6;
        LPC_PWM1->MR6 = 0;
        /* all PWM latch enabled */
        LPC_PWM1->LER = LER0_EN | LER1_EN | LER2_EN | LER3_EN | LER4_EN | LER5_EN | LER6_EN;
  else
        return ( FALSE );               /* Unknown channel number */
  NVIC_EnableIRQ(PWM1_IRQn);
  return (TRUE);
** Function name:               PWM_Set
** Descriptions:                PWM cycle setup
** parameters:                  Channel number, PWM cycle, and offset
void PWM_Set( uint32_t ChannelNum, uint32_t cycle, uint32_t offset,double duty_cyc)
        LPC_PWM1->MR1 = cycle * 1/3 +offset;
        LPC_PWM1->MR2 = cycle * 1/3 +offset;
        LPC_PWM1->MR3 = cycle * 1/2 +offset;
        LPC_PWM1->MR4 = cycle * 1/3 +offset;
        LPC_PWM1->MR5 = cycle * 1/6 +offset;
        LPC_PWM1->MR6 = offset;
        /* The LER will be cleared when the Match 0 takes place, in order to
        load and execute the new value of match registers, all the PWMLERs need to
        reloaded. all PWM latch enabled */
  return;
** Function name:               PWM_Start
** Descriptions:                Enable PWM by setting the PCR, PTCR registers
** parameters:                  channel number
void PWM_Start( uint32_t channelNum )
  if ( channelNum == 1 )
        /* All single edge, all enable */
        LPC_PWM1->PCR = PWMENA1 | PWMENA2 | PWMENA3 | PWMENA4 | PWMENA5 | PWMENA6;
        LPC_PWM1->TCR = TCR_CNT_EN | TCR_PWM_EN;     /* counter enable, PWM enable */
  return;
** Function name:               PWM_Stop
** Descriptions:                Stop all PWM channels
void PWM_Stop( uint32_t channelNum )
        LPC_PWM1->PCR = 0;
        LPC_PWM1->TCR = 0x00;                /* Stop all PWMs */
  return;
