in application programming does not jump to user app
Hi there,
I tried to execute the IAP code (AN3965) on a f4 discovery board. I can say that the loader reads an writes binarys perfectly, it was testet with flash loader demonstrator.
But jumping to user app does not work. I tried the following pieces of code, I get everytimes a hard fault at the command 'Jump_To_Application();'
What is wrong?
code one:
/* Jump to user application */
JumpAddress = *(__IO uint32_t*) (APPLICATION_ADDRESS + 4);
Jump_To_Application = (pFunction) JumpAddress;
/* Initialize user application's Stack Pointer */
__set_MSP(*(__IO uint32_t*) APPLICATION_ADDRESS);
code two:
volatile uint32_t JumpAddress;
void (*Jump_To_Application)(void) = 0;
Jump_To_Application = (void (*)(void)) JumpAddress;
