I wish to simulate the code in ARM 2378 using Keil uVision 4 in my Windows 7 OS. But when I start to create a project, it asks me to select the project target. In the list of various NXP targets, LCP2378 isn't found. What to do ... ?
Can anyone help me out? Am I missing something or should I separately include targets..(if so, how to do it?)
Arithy.
You mean in the device selection list in the project options? I see it there.
wat if i dont see it n the project target list..? wat to do to include it ...?
I can't understand how it can be missing. Which version do you have? Do you see other LPC models?
Maybe try to uninstall and install again your software.
I use keil uVision4 for 8051 . in fact, the LCP2478 is available in the project of Keil at my office... but when i try it in my PC, its not there... i tried reinstalling as well,.. its all the same.. :(
I think it is because you do not have an application license for the ARM models.
If you install the free lite version then you will be able to use ARMs for up to 32K code
I have noticed than in the download page the c51 and ARM version are separate packages so I think you need to install the MDK-ARM if you only have the C51 version.
well, thnx .. i'll try it nd let u know :)
