Hello all, I am using 8051 controller with UART working. I am generating interrupt for UART RX.
in main() I am sending one string to hyperterminal through UART TX and I can see it on Hyperterminal i.e my UART TX is working. I am sending one string to UART RX through hyperterminal and I can see it in my UART RX interrupt i.e my UART RX with interrupt is also working. I could establish the communication between hyperterminal on PC and UART_TX_RX on controller.
Now,My transmit code: 1. I am transmitting one string to hyperterminal from UART TX and I can see it on terminal say for example "ABC" 2. I am waiting for response from hypterminal say "123", using following loop 3. and when I get the required string I will come out of the loop
extern volatile unsigned char rx_buf[20; #define DETECTED_STR "123" Transmit_string("ABC"); while(strncmp((const char *)DETECTED_STR,(const char *)rx_buf,4)); Delay();
Now,My receive code:
volatile unsigned char rx_buf[20]; void sci0rx_isr(void) { rx_buf[index] = SCI0.RDR; SCI0.SSR.BIT.RDRF = 0; }
if I omit while loop I will get interrupt and string correctly. but I dont get the interrupt, if I add while loop. Wait there and do not proceed further until I get the required string.
ISR is at highest priority even then it can not interrupt while loop. Please provide the solution for that
Hello all, sorry it is not a 8051 controller but renesas controller. My problem is not related to controller but ISR interrupt with while loop so I posted code here regards
Do you increment the index? Do you NUL terminate the string?
Hi, Thanks for reply. if I add while loop and while running I put breakpoint in ISR routine and then run the code. If I send any data from hyperterminal, ideally it should break the while loop and jump to ISR where I breakpoint is placed. but flow doesnt go there it is stuck in while loop, this I can see if I pause the debugger. Interrupt is not at all occured. regards
What makes you think it is even safe to do a strcmp() while the interrupt is expected to add more characters to one of the two buffers used as parameters for strcmp()? How is the zero-termination handled?
