Hello, I am using Keil uvision 4 (arm-mdk453 package) for STM32VL discovery board. It used to be working properly, but now I'm having a problem when I try to download to flash or to debug. I receive popup messages like ''Internal command error'', ''Flash download failed: target dll has been cancelled''. I did upgrade to (mdk454 package) but still have the same problem. Any help will be highly appreciated.
Best Regards,
Hello. Try to use "STVP" from ST (you can find it at whttp://www.st.com, STVP - ST Visual Programmer for programming ST7, STM8, STM8T and STM32, "ST Toolset including ST Visual Develop (STVD)and ST Visual Programmer (STVP)"). I had the same problem with ST Discovery board(messages like ''Internal command error'', ''Flash download failed: target dll has been cancelled''). I chose "Erase Active sectors" in stvp's menu, and then Keil worked without problems.
This works for me. Thank you very much.
