Urgent please,I need to interface My EasyWIFI to 8051/PIC microcontroller.I am a novice in this.Please i will be happy if i can get like a reference code on it.
"Urgent"
www.catb.org/.../smart-questions.html
"I am a novice in this. Please i will be happy if i can get like a reference code on it."
Then you will just be a novice with some code. How will you understand it? What will you do with it?
It's like saying, "I want to drive across the country. I don't know how to drive. Please give me a car"
If you're a novice, you need to start by learning the basics.
Suggestions for starting with 'C': blog.antronics.co.uk/.../08
Essential reading for starting with the 8051:
http://www.8052.com/tutorial http://www.keil.com/books/
These 3 form the so-called "bible" for the 8051: www.classic.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf www.classic.nxp.com/.../80C51_FAM_HARDWARE_1.pdf www.classic.nxp.com/.../80C51_FAM_ARCH_1.pdf
Apart from what can be judged by the style of the post, do we know anything about the skills of the OP?
Something could quite legitimately be added to your rather poor example:
It's like saying, "I want to drive across the country. I don't know how to drive. Please give me a car so I can take the first step and arrange some lessons"
Yes, it does happen. My son recently asked me something very similar!
A person can consider themself a novice in a subject, even after reading through all the relevant specifications and datasheets. Sample code (from a manufacturer for example) can be the catalyst needed to trigger deeper understanding.
Thanks a lot for your quick response Andrew Neil.But do not misunderstand my statement,been a novice does not mean i do not know anything about microcontrollers.Actualy,what i need to achieve is interfacing easywifi module with microcontroller and i just want to know if anyone can actually assist me on it.I can use RF module very well but in this project i need an internet wireless communication which means i must have a fixed frequency wireless transceiver module.
Why do you feel the need to make your entire post bold?
"i need an internet wireless communication which means i must have a fixed frequency wireless transceiver module."
No, it does not mean that at all!
You mentioned a particular module - have you read its documentation?
What specific difficulty/difficulties are you having?
Ah, you actually said, "My EasyWIFI" - what did you mean by that?
Is that a module, or a service - or what?
http://www.easywifi.com/ ?? It looks like it is a service. So you would need to get a WiFi Module. A full one, since an 8052 may not be big enough to run the protocols. Then you need info from easywifi to connect to their network.
Thanks Neil,But the easyWIFI is a board that carries It carries MRF24WB0MA Wi-Fi radio transceiver module.you can check this link for the board manual www.mikroe.com/.../
