__task void ParameterManager::ParameterManagerTask() { // Reset all Constants ParameterManager::GetParameterById(ParameterId_Vendor)->setValue((char*)&Vendor, 2); while(true) { } }
Our target board is wired with ARM7 LPC2468 Microcontroller. Our embedded application is written in 'C++'. This code base was working fine. Recently number of changes were made and now I'm stuck in while(true). This task keeps running. No other task gets to run. Why might this task be running all the time ?
The kernel apportions how time (quanta, slots, slices) get allocated between running tasks, if there are no interrupts there is no way of marking time, or switching tasks.
Sitting in a tight loop with interrupts disabled isn't going to play well with other tasks.
Instead of focusing on the loop, focus on the bigger picture of how the OS functions, and how the other tasks interact with it.
>> If interrupts are blocked, then the kernel will not see time, so it will not know when to task-switch.
What do you mean by "kernel will no see time" ?
I did DIFF. Previously, this task was blocked waiting on mailbox. Presently, there is no blocking on this task and higher priority tasks are suspended waiting on something, so this is the only task running.
Correct! this task was starving tasks with lower priority. Correct! I should just kill the task. There is no use to have a task that only consumes CPU.
I solved the problem by blocking this task forever because it doesn't do anything.
>> Are interrupts enabled, are other interrupts occurring? Was this question asked because interrupts may be setting events that would move tasks from suspended to ready state?
Thank you very much for solving this problem!
Only the idle task should really have an infinite loop like this - any task with higher priority will starve any task with lower priority.
And since your task can't get out of your infinite loop, you can just as well kill the task. What use is there to have a task that can only consume CPU?
Seems like the priorities of tasks have been changed. Is the task assigned highest priority??
Then do a DIFF against the code that was working and consider what changed from there, showing us a while() loop doesn't help anyone here.
Consider if you have assigned this task a higher priority, or if all other tasks are suspended waiting on something that is never going to occur?
undoing the Two user commands doesn't make any difference.
I noticed one change in build as follows:
User command #1: C:\Keil\ARM\BIN40\fromelf.exe -v --bin --output Builds\filename.bin Builds\filename.axf
User command #2: ..\..\..\..\Tools\BuildTools\AppendCrc.exe Builds\filename.bin
Our previous build that works doesn't have these two build commands.
