Hi! I work with Actel FPGAs. I need to connect core8051s. I created a project in FPGA, but I can not program the microcontroller. In Kit A3PE-A3P-EVAL-BRD1, no external memory, I have created in the FPGA RAM ROM, but can not be programmed. Who has seen this problem? There is an example of a solution? Working examples of projects in the Libero and Keil or SoftConsol? Thank you!
"Can the processor use register [...]"
Might there exist documents that answers this kind of questions? Would anyone else be able to answer your question if they haven't looked at such documents? Any reason why you aren't busy trying to locate a proper document, to find the answer yourself?
