Hi! I work with Actel FPGAs. I need to connect core8051s. I created a project in FPGA, but I can not program the microcontroller. In Kit A3PE-A3P-EVAL-BRD1, no external memory, I have created in the FPGA RAM ROM, but can not be programmed. Who has seen this problem? There is an example of a solution? Working examples of projects in the Libero and Keil or SoftConsol? Thank you!
I have read HB UG for core8051s. I worked with the 8051 and the FPGA. My problems with the programming of the 8051 in FPGA. Solve such a problem? Thank you.
But you've given no indication whatsoever of what what "problems" you are having - so how do you expect anyone who's never seen your project to be able make any suggestions?!
It's not even entirely clear what, exactly, you mean by "programming"...
I created the hex file. How to program it in core8051s? Programmer Actel FlashPRO?
If it's supposed to be a "ROM", then you'd need to get the HEX data into a form that the chip compiler can include it as it builds the core? Aren't there any manuals for your chip/tools?
