acuisition square wave
First, I apologize for the bad English , I'm using a translator atomatico .
I started using the card - SAM3U -EK Atmel to generate a square wave and two continuous signals , commanding the PC via serial communication from the start and stop signals . I managed to do it fairly easily thanks to the software example that I found on the Internet . I then connected the PC to the UART port of the card. I generated the square wave output PA7 , while the two continuous signals have them generated as square wave duty cycle 100 , the outputs PA8 and PA9 .
Now I would have the need to acquire a square wave of predetermined frequency , and calculate the duty cycle of the same . The duty cycle value must then send to the PC , and I thought to do it using the other serial port on the card ( USART ) or via the USB port.
Do you have any advice? Do you have any sample program that I can be of help ?
All this and ' part of a project , just born , for industrial simulation .
Thank you very much , kind regards
Alessandro Parodi
