i want to set the baud rate of AT89S52 to 9600 to connect to a wireless module that work on the same baud rate . The output should be any number from 1 to 9. This is my code for the serial port, but using it gives a wrong output on the hyper terminal ex if no. 1 is pressed the putput is 81818181818181..... If anyone could help to figure out the problem?
void UART_Init() { TMOD |=0x20; //Timer1 in Mode2. TH1= 0xE6; // 9600 Baud rate at 12MHz SCON=0x50; // Asynchronous mode 8-bit data and 1-stop bit TR1=1; //Turn ON the timer. TI=1; // TI: set TI to send first char of UART
} void UART_Tx(int ch) { SBUF=ch; // Load the data to be transmitted while(TI==0); // Wait till the data is trasmitted TI=0; //Clear the flag for next cycle. }
Thank you in advance.
you can't do 9600 with 12MHz and T1 you have two possibilities 1) replace the crystal with a standard 11.0592 MHz 2) use T2
