I am working with MCBSTM32 board. My ULINK2 Debug Adapter is broken and I tried to use ARM-USB TINY H converter instead. I am also using keil uvision IDE. When I load the program, I receive the error message of "no ULINK device is found”. My questions are : Can I use ARM-USB TINY H converter instead of ULINK2 Debug Adapter? If yes, can I still work in keil uvision IDE?
Yes, you can probably use it as a JTAG debugger, with software that supports it. No, unless you have some drivers for Keil (RDI?), or ability to select it from the debugger menu.
