Is there a way for a program to know if it's executed under the simulator and not on an actual CPU?
Alright, here's my solution for LPC2xxx chips, in case anyone is interested. It is based on the fact that most flash programming tools modify the program image in such a way that the sum of all interrupt vectors in the boot block will be 0, whereas under the simulator the program is executed "as is", without any modification.
#include <stdint.h> #include <stdbool.h> bool in_simulator(void) { uint32_t sum = 0; uint32_t * p; for (p = 0; p < (uint32_t *)0x20; p++) sum += *p; return sum != 0; }
I doubt that anyone cares, but any criticism and suggestions are welcome :)
But that reasoning, what you're describing isn't what you said you wanted to have. It's a way to detect flash programming tools' checksumming of the vector table, not one to detect the simulator.
And of course, nothing stops the person configuring the simulator from implementing the same kind of checksumming either to the program itself, or as part of the debugger startup script, thus completely fooling your "detection".
The reasoning is that a program without a correct checksum wouldn't get executed on an real CPU in the first place. So if it still does, it is very likely that it is executed under the simulator. But I agree this isn't a 100% sure method and this is the reason why I invited suggestions from people :)
Of course, nothing stops the person from configuring the simulator in such a way, as well as nothing makes the person do so, particularly as "the person" in question is me :) I can't think of a situation where someone would easily change configuration of my simulator and make these settings permanent for all projects without me noticing it.
Besides, I would be interested to take a look at the actual steps to "fool" the program into thinking it's run on the real hardware (bit of a script or anything). Honestly speaking, I don't even know how it could be done at the moment.
The CPU doesn't check the vector's checksum, that would have to be something else running on the core like a boot loader.
A more effective method would be to determine a hardware register that the simulator fails to accurately reflect that of real hardware. ie bits stuck at zero or one, due to lack of silicon defining a function, or bits that are random, toggle, or reflect some state in another register. I might look at clock enable registers, or those within timers, there are hundreds of targets in any given SoC implementation.
That's right. This check is only reliable on LPC2xxx-based ISP-programmable devices, all of which come with a boot loader.
This is something to think about but so far I see two problems with this:
1) As you yourself have said, there are hundreds of registers that the simulator supports, so determining one that it fails to accurately simulate would be like looking for a needle in the hay. Besides, I have no idea how exactly to do this.
2) Such an inaccuracy is not an officially supported feature and relying on such things is generally a bad idea. The developers may change the behaviour of that register in the next release and our check will turn out invalid.
Is there a way to get in touch with the simulator developers and ask them this question?
Given this isn't a gate level simulation, I'd think there are more needles than hay. It's a target rich environment that's been optimized for speed not authenticity. If documented features limit you, strap some wire or logic externally that the simulator couldn't possibly know about.
Why is this important anyway? And why do you need to rely on it?
Well, certainly it's not so important since I've found a solution to my particular problem :) But I'm surprised there's no general/official way to do this kind of check and nobody even cares about it! Before posting here I did some googling and found nothing, not even a single mention of the problem! I'm sure I'm not the first person to need this.
So, I hope some simulator experts might see this thread and shed some light :)
You did quote two questions.
But none of your own text did answer any of the two questions. We still don't know the answer to the "why"...
You mean why a program would need to know whether or not it's running under the simulator? I need that for debugging. I cannot use any of the debug adapters due to the specifics of our device, so I have to use the simulator extensively. And as the simulator doesn't support many of our peripherals, I have to turn off some program components when I want to debug some others. Basically, I have to implement two configurations for the program depending on where it's being executed.
You seem to have completely overlooked that the reason for nobody mentioning this problem might be that this is not a problem. That's a typical result of trying to hide the context of your request from the people you seek help from.
And if you had told us that right away, you would have got the solution to your actual problem much earlier, rather than not-quite-solutions to what you thought the problem was.
You do not need to do detect the simulator. You need to tell your program that it's running in the simulator. That's what multi-target projects and compiler switches are for. You just build a special version of the program tailored to working on the simulator, and that's that.
I have to agree with that. It's probably an error on his part and likely to be a one off.
This is inconvenient to me. I'm running the program on the device and when I see something go wrong I launch the program in the IDE - and it's the same program, I don't need to change 10+ switches and recompile it.
So I definitely knew what I was doing when I was asking how to detect the simulator and not how to use compiler switches :)
and it's the same program, You say that as if it were the solution to some problem. But it's not. It's actually a problem which you introduced into your program. Did you ever ask yourself what would happen if your simulator detection ever randomly failed on real hardware? Well, your "solution" will then turn off a whole series of important peripherals because it believes it's running in a simulator. Bad news. This is not code you want to have in your actual production executable.
If you truly believe you need "10+ compiler switches" to achieve this, maybe you should get on-site help with this project of yours.
I was writing my last message late at night in local time and I didn't think very well... Of course you could get along with only one compiler switch, but you still have to remember to change that switch and recompile the program every time you want to run it on the simulator. Not a problem? Well maybe :) But this has been bugging be for the last few days as the program is being actively developed.
Can you give a realistic scenario of how the code in the second post could fail on real hardware? :) But your point still makes sense. I'll probably have to condition it out of the production build, thanks for the tip-off!
Congratulations, you're now only half a step away from figuring out why my recommendation mentioned not just compiler switches, but also multiple targets in one IDE project. One of those could conveniently called, hmm, let's see, "Debug" and differ from the other one ("Release", maybe?) by a) the detailed configuration and initialization sequence for your debugger of choice: the simulator, and b) any and all other changes necessary to configure the program for debugging, e.g. compiler switches, or reduced optimization flags.
This approach does violate an important rule in safety conscious embedded development: you debug what you fly, and you fly exactly what you debugged. But if that's truly not an option, as you claimed, then there's nothing significant left to be lost by tailoring the debug build for optimal debugging capabilities.
I am using uVision V4.60.0.0 and I haven't noticed any "multiple targets" facility in it. It does support "Multi-Project Workspaces" though, which basically means that you can edit and compile two or more projects at the same time. Presumably I could create a parallel "Debug" project and compile it along with the "Release" one. But then I have to 1) keep the two projects in sync and 2) put up with the fact that compilation now takes two times as longer (or I still have to remember to recompile).
Well, I don't know... I still haven't seen any strong arguments as to why my method may fail and why having to maintain two projects instead of one is safer and facilitates debugging.
That being said, you've sowed a grain of doubt in me. I guess I have to think more about it. Anyway, thank you everyone for your input :)
I haven't noticed any "multiple targets" facility in it. Then maybe you haven't looked very thoroughly. Let me point your attention to the Project->Manage->Components,... dialog, and the fact it has a list of Project Targets for you to manage.
Actually you have. You even put the most important one right above your own description of your proposed solution. You wrote that most flash programming tools do that checksumming you intend to base your solution's design on. Someone replied that only tools for one particular brand of ARM micro controllers really do that.. So where exactly does your sudden confidence come from that this will always be the case? How do you plan on excluding the possibility that your program will, at some point, by somebody you've never spoken to, be flashed by a programming tool that doesn't follow that scheme?
