I have a firmware runing fine with UART1 as a normal IRQ.
Recently I realize that I should use UART1 as a FIQ to be sure that the communication works fine.
As an IRQ I had the this defintions: "... VICVectAddr7=(unsigned long) ISR_UART1; VICVectPriority7=0x00000008; VICIntSelect &= 0xFFFFFF7F; VICIntEnable |= 0x00000080; ..." "... void ISR_UART1 (void) __attribute__ ((interrupt("IRQ"))); ...."
void ISR_UART1 { .... .... cTmp=U1IIR; VICVectAddr = 0x00000000; }
As a FIQ I changed to:
As an IRQ I had the this defintions: "... VICIntSelect |= 0x00000080; VICIntEnable |= 0x00000080; ..." "... void FIQ_Handler(void) (void) __attribute__ ((interrupt("FIQ"))); ...."
void FIQ_Handler(void) { DEBUG = 1 DEBUG = 0 DEBUG = 1 ISR_UART1(); //it is the only one FIQ so I call imediatly this funciton DEBUG = 0 }
With the osciloscope I can see the the Debug going '1'->'0'->'1' but it never leaves the function and don't get the final '0'.
Can anyone help me with this???
Do you really think a FIQ handler should call an IRQ handler?
Shouldn't you just throw away your new FIQ handler and instead adjust the UART code to be a FIQ handler? After all, you don't want to waste time with an extra function call.
Problem resolved.
The problem is that I leave the code:
And when I call the function ISR_UART1 the program don't leave this function. I think that the problem is because of this: 1- When start FIQ_Handler the CPU saves the LR making a PUSH. 2- Then I was calling the ISQ_UART1 (with the statement: void ISR_UART1 (void) __attribute__ ((interrupt("IRQ"))); ) So the LR was saved with a PUSH to the stack 3- When the ISR_UART1 ends it makes as operation like RETI (return from an Interrupt). with this the CPU will load the LR previous to the call of the ISR_UART1.
I think the problem was something like this.
Thanks, Carlos Costa
Yes - as I indicated in my first post, a FIQ handler isn't supposed to run any code that thinks it is an IRQ handler. That will seriously break the intended use of the stacks for FIQ and IRQ processing.
