Hello Everyone, Generally when interfacing LCD with my controller (AT89C52),in 8 bit mode I use a full port for my data lines. and I get the desired result.
But I have seen many projects where the data lines are split up in to two different ports, d0 to d3 in one port and d4 to d7 in another. Could someone please explain to me how this works or maybe please give me an example to work with.
Thanks in advance, Arun
most probably this kind of splitting will be carried out while interfacing with seven segment display only for few cases while interfacing with LCD,there, they will use four to eight driver IC
