Hi,there, I'm a starting programmer and a Linux amateur. I'm orienting to be a completely Linux user. I used Keil uvision when I used MS-OS. Please advice me of a mature software to use in debugging my firmwares.
Thank you in advance!
You somehow managed to forget to mention any processor.
The market for expensive and effective tools, and linux, are not wholly coherent.
If some basic searching, or coding one's own tools, doesn't present solutions, you might need to reconsider the effectiveness of your strategy as expressed.
Hello, again,
I'm working on an Opensuse 11.0-i586 operating system, AMD -64bit processor, in a laptop configuation. the operating system was successfully installed as I probed different softs on it. In my low level fast app, I intend to program an ARM cortex M3, or 4 I didn't make my final choice yet.
The programming process topology I used to work with can be concluded as follows:
Intl+MSWin+Softpackage----->> External CPU burner ----->> and My breadboard,
So I just wish to know if there is a similar topology to use in Linux, I'd appreciate any other suggestions, or any enlightening.
Thanks,
Thank you guys!
With ur advices, it is worth a start
