I tried to download my program onto the MCB4300 eval board with a Ulink2 adapter and received the error 'Flash Timeout. Please Reset Target and Try Again.' This is followed by a message 'Flash Download failed - Cortex M4'. In the output window, it says 'Erase Failed'.
Even after resetting the target, the issue was not resolved. What may be causing this issue?
Thanks in advance!
I tried to download my program by which means?
It turns out that I needed to include an ini file under the Utilities tab of Options for Target as well. I only had it in the Debug tab. Plus, there was an issue with my ini file. Everything worked when I used the Blinky project ini file.
The issue is resolved now. Thank you though!
