Hi everyone, I am trying the firmware blinky on a lm3s9b92 inserted into directory of Keil. I have compiled without errors, but when I run the debugger in the command window exits the error 65 access violation at 0x400fe108 : no 'write' permission. On the other hand, if i compile the same code with a lm3s811 the debugger everything goes well. I have not made any change to the firmware you can give me some advice. thanks
As far as I remember, lm3s811 is quite different with lm3s9b92.
0x400fe108 supposed to be an address of Peripherals.
It looks like that, lm3s811 has such a peripheral, lm3s9b92 doesn't.
Stellaris LM3S9B92 Microcontroller DATA SHEET Copyright 2007-2012 Texas Instruments Incorporated DS-LM3S9B92-11425 TEXAS INSTRUMENTS-PRODUCTION DATA
Register 33: Run Mode Clock Gating Control Register 2 (RCGC2), offset 0x108 This register controls the clock gating logic in normal Run mode. Each bit controls a clock enable for a given interface, function, or module. If set, the module receives a clock and functions. Otherwise, the module is unclocked and disabled (saving power). If the module is unclocked, reads or writes to the module generate a bus fault. The reset state of these bits is 0 (unclocked) unless otherwise noted, so that all functional modules are disabled. It is the responsibility of software to enable the ports necessary for the application. Note that these registers may contain more bits than there are interfaces, functions, or modules to control. This configuration is implemented to assure reasonable code compatibility with other family and future parts. RCGC2 is the clock configuration register for running operation, SCGC2 for Sleep operation, and DCGC2 for Deep-Sleep operation. Setting the ACG bit in the Run-Mode Clock Configuration (RCC) register specifies that the system uses sleep modes.
