blinky error with lm3s9b92
Hi everyone,
I am trying the firmware blinky on a lm3s9b92 inserted into directory of Keil. I have compiled without errors, but when I run the debugger in the command window exits the error 65 access violation at 0x400fe108 : no 'write' permission. On the other hand, if i compile the same code with a lm3s811 the debugger everything goes well. I have not made any change to the firmware you can give me some advice.
thanks
