Cant intialise data value from data area readwrite
I have just started writing assembly code. I am using the simulator in Keil uvision5 to the run the code below. I dont understand why I can't see the src data value of 14 in register r1 when I ldr the data value from the address stored in the r0 register. I have tried to research the solution myself but cant find an exact reason why this happens. Any help would be gratefully appreciated.
  THUMB
  AREA RESET, CODE, READONLY
  EXPORT  __Vectors
  EXPORT Reset_Handler
__Vectors
  DCD 0x20001000
  DCD Reset_Handler
  AREA Code, CODE, READONLY
  ENTRY
Reset_Handler
        LDR     r0, =src
        LDR     r1, [r0]
terminate  ; sit in an endless loop
  B terminate
    ; data area that can be modified (readwrite)
  AREA Data, DATA, READWRITE
src     DCD     14
        END
  • This is due to the way you have the linker configured (scatter file), and that statics bound for RAM are placed into the back end of the FLASH/ROM portion with the expectation that start up code (either the C run time library, or your own) will copy the statics and zero other regions. When the processor resets the RAM is assumed to contain garbage, and must be loaded with the default/expected values.
    Your code does not provide any copying function, the processor starts and goes directly to your code. The routine __main normally does this before calling your own main() function.
    So either place your constants in FLASH, or take more ownership of copying them too RAM.
    You might want to search on the linker documentation, and the concepts related to startup from ROM.
