Hello! I have a MCBSTR9 chip and i am trying to use the UART for sending some characters to the chip. All works great in simulator but when i am loading it on the chip it doesn't do anything at all. What would be the problem? Here is the source code:
/******************** (C) COPYRIGHT 2007 STMicroelectronics ******************** /* Includes */ #include "91x_lib.h" void init_serial (void) ; /* Private typedef */ /* Private define */ #define TxBufferSize (countof(TxBuffer) - 1) /* Private macro -*/ #define countof(a) (sizeof(a) / sizeof(*(a))) /* Private variables */ UART_InitTypeDef UART_InitStructure; u8 TxBuffer[] = "UART Example1: UART \n\r"; u8 current; u8 NbrOfDataToTransfer = TxBufferSize; u8 TxCounter = 0; u32 pins[] = { GPIO_Pin_0, GPIO_Pin_1, GPIO_Pin_2, GPIO_Pin_3, GPIO_Pin_4, GPIO_Pin_5, GPIO_Pin_6, GPIO_Pin_7 }, i, car; /* Private function prototypes */ void SCU_Configuration(void); void GPIO_Configuration(void); static void Delay(u32 nCount); * Function Name : main *******************************************************************************/ u8 R; int main() { #ifdef DEBUG debug(); #endif /* Configure the system clocks */ SCU_Configuration(); /* Configure the GPIO ports */ GPIO_Configuration(); /* UART0 configuration -*/ /* UART0 configured as follow: - Word Length = 7 Bits - Two Stop Bit - No parity - BaudRate = 115200 baud - Hardware flow control enabled (RTS and CTS signals) - Receive and transmit enabled - Receive and transmit FIFOs are enabled - Transmit and Receive FIFOs levels have 8 bytes depth */ UART_InitStructure.UART_WordLength = UART_WordLength_8D; UART_InitStructure.UART_StopBits = UART_StopBits_1; UART_InitStructure.UART_Parity = UART_Parity_No ; UART_InitStructure.UART_BaudRate = 9600; UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_None; UART_InitStructure.UART_Mode = UART_Mode_Tx_Rx; UART_InitStructure.UART_FIFO = UART_FIFO_Disable; UART_DeInit(UART0); UART_Init(UART0, &UART_InitStructure); /*enable UART Rx Interrupt*/ UART_ITConfig(UART0, UART_IT_Receive , ENABLE); /*configure UART0 interrupt in VIC*/ VIC_DeInit(); VIC_InitDefaultVectors(); /* initialize VICs default vector registers*/ VIC_Config(UART0_ITLine, VIC_IRQ, 0); /* Enable the UART0 */ UART_Cmd(UART0, ENABLE); /* Communication hyperterminal-UART0 using the hardware flow control */ /* Send a buffer from UART to hyperterminal */ /* while(NbrOfDataToTransfer--) { UART_SendData(UART0, TxBuffer[TxCounter++]); while(UART_GetFlagStatus(UART0, UART_FLAG_TxFIFOFull) != RESET); }*/ /*enable UART0 interrupt for data reception*/ VIC_ITCmd(UART0_ITLine,ENABLE); while (1) { //send data UART_SendData(UART0, R); //set pins for(i = 0, car = (u32)R; i < 8 && car; i ++, car = car /2){ if(car % 2 == 1) GPIO_WriteBit(GPIO7, pins[i], Bit_SET); else GPIO_WriteBit(GPIO7, pins[i], Bit_RESET); } } } * Function Name : SCU_Configuration *******************************************************************************/ void SCU_Configuration(void) { SCU_MCLKSourceConfig(SCU_MCLK_OSC); /* Default configuration */ /*wait state insertion :This function should be executed from SRAM when*/ /*booting from bank1 to avoid Read-While-Write from the Same Bank.*/ FMI_Config(FMI_READ_WAIT_STATE_2, FMI_WRITE_WAIT_STATE_0, FMI_PWD_ENABLE,\ FMI_LVD_ENABLE, FMI_FREQ_HIGH);/*Insert 2 Wait States for read*/ SCU_PLLFactorsConfig(192, 25, 2); /* PLL factors Configuration based on*/ /* a OSC/Crystal value = 25Mhz*/ SCU_PLLCmd(ENABLE); /* PLL Enable and wait for Locking*/ SCU_RCLKDivisorConfig(SCU_RCLK_Div1); /* RCLK @96Mhz */ SCU_HCLKDivisorConfig(SCU_HCLK_Div1); /* AHB @96Mhz */ SCU_FMICLKDivisorConfig(SCU_FMICLK_Div1);/* FMI @96Mhz */ SCU_PCLKDivisorConfig(SCU_PCLK_Div2); /* APB @48Mhz */ SCU_MCLKSourceConfig(SCU_MCLK_PLL); /* MCLK @96Mhz */ /* Enable UART0 Clock */ SCU_APBPeriphClockConfig(__UART0, ENABLE); /* Enable VIC clock */ SCU_AHBPeriphClockConfig(__VIC, ENABLE); /* Enable GPIO2 Clock */ SCU_APBPeriphClockConfig(__GPIO2, ENABLE); /* Enable GPIO3 Clock */ SCU_APBPeriphClockConfig(__GPIO3, ENABLE); /* Enable GPIO5 Clock */ SCU_APBPeriphClockConfig(__GPIO5, ENABLE); } * Function Name : GPIO_Configuration *******************************************************************************/ void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; /* GPIO Configuration */ SCU->GPIOOUT[7] = 0x5555; /* P7.0..7 output - mode 1 */ GPIO7->DDR = 0xFF; /* P7.0..7 Outputs (LED Data) */ /*Configure UART0_CTS P2.0*/ GPIO_DeInit(GPIO2); /*After DeInit function P2.0 = UART0_CTS (defaut configuration)*/ GPIO_DeInit(GPIO5); /*Gonfigure UART0_Rx pin GPIO5.1*/ GPIO_InitStructure.GPIO_Direction = GPIO_PinInput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_IPInputConnected = GPIO_IPInputConnected_Enable; GPIO_InitStructure.GPIO_Alternate = GPIO_InputAlt1 ; GPIO_Init (GPIO5, &GPIO_InitStructure); GPIO_DeInit(GPIO3); /*Gonfigure UART0_Tx pin GPIO3.4*/ GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt3 ; GPIO_Init (GPIO3, &GPIO_InitStructure); /*Gonfigure UART0_RTS pin GPIO3.3*/ GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt3 ; GPIO_Init (GPIO3, &GPIO_InitStructure); } /******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
Thank you !
