Hi All, Does any one know what is required to work with the Ember Zigbee Pro network stack ?
SiLabs prefer to use the IAR workbench.
I have connected a Ulink2 to the telegesis ETRX357 module and the target is reset OK through the JTAG interface but no JTAG IDs are detected.
Many thanks, John
Err... wouldn't Ember know that?!
Thank you for your help.
They only support IAR. Keil docs just seem to show no more than the EM357 data sheet.
You mean Ember?
The big question is whether any library files, etc, are in a format compatible with Keil.
I guess you need to ask yourself which is the most important to you - to use Keil as your develpment toolset, or to use the Ember stack...?
Their Stack is statically linked and is not rocket science to join any differing data alignment.
