LPC1769 LpcXpresso EMAC
Hi, I want to port some LPC1768 code to an LPC1769 LpcXpresso board. The problem is that the project EMAC (EMAC_LPC17xx.h) uses the DP83848C phy and the LpcXpresso uses the LAN8720A.
I was going to modify the header file by replacing the PHY constants with ones from EMAC_LPC177x_8x.h (which has LAN8700 consts). Will this work or is there an easier way? Thanks Ian
