Hello, I am a complete beginner when it comes to keil, but I want to learn. However I stumble upon different stuff and get stuck, so I thought it was about time to ask for some help.
I work on MCBSTR9 (ARM STR912FW44) and I would like to make something simple: when I press one interrupt button on the board to light up some of the LEDs and when I press the other interrupt button to light some of the other LEDs.
From what I read I can use the interrupt handlers and all I would have to do is write code in the following function:
void WIU_IRQHandler(void) { }
This function is found in the 91x_it.c file.
I found these functions for handling interrupts: VIC_DeInit = Deinitializes the VIC module registers to their default reset values. VIC_GetIRQStatus = Gets the status of interrupts after IRQ masking. VIC_GetFIQStatus = Gets the status of interrupts after FIQ masking. VIC_GetSourceITStatus = Gets the status of the source interrupts before masking. VIC_ITCmd = Enables or disables the interrupt request lines. VIC_SWITConfig = Generates a software interrupt for the specific source interrupt before interrupt masking. VIC_ProtectionCmd = Enables or disables the register access protection. VIC_GetCurrentISRAdd = Gets the address of the currently active ISR. VIC_GetISRVectAdd = Gets the ISR vector addresses. VIC_Config = Configures the ISR, the line, the mode and the priority for each interrupt.
WIU_Init = Initializes the WIU according to the specified parameters in the WIU_InitTypeDef structure WIU_DeInit = Deinitializes the WIU registers to their default reset values WIU_StructInit = Fills each WIU_InitStruct member with its reset value. WIU_Cmd = Enables or disables the WIU peripheral. WIU_GetITStatus = Checks whether the specified WIU line is asserted or not WIU_ClearITPendingBit = Clears the pending bit of the selected WIU line WIU_GenerateSWInterrupt = Generates a Software interrupt for the specified line WIU_GetFlagStatus = Checks whether the specified WIU line flag is set or not. WIU_ClearFlag = Clears the WIU line pending flag.
I think I managed to configure them, however, I can't figure out how to use these functions in order to find out how to get the specific interrupt I want (pressing one of the 2 buttons on the board). If anyone could also point out how to do this in the simulator I would be really grateful.
Have a great day!
Do you have experience with other embedded tools and/or processors?
"I work on MCBSTR9"
Have you looked at the examples for that board?
No, I don't have any other experience with embedded processors.
Regarding examples, from what I have, I think it's just a framework. I have a project named WIU, but it doesn't do anything apart from the initialization of the VIC and WIU and I didn't find anything else.
I wouldn't recommend STR9 as a good place for a beginner to start.
