Static array declaration crashes application.
I'm using Keil IDE V4.23.00.00.0.
If I declare some static array in module A like:
volatile static unsigned char MyArray[9]
then all works fine.
If I declare it like:
volatile static unsigned char MyArray[8]
then another module B generates a HARD FAULT interrupt.
Module B does not use or has any connection with module A.
If I look in the .map file I see:
MyArray[9]
.bss                        0x20003a40   Section      500  f991_dma1forusart2.o(.bss)
.bss                        0x20003c34   Section        9  fa30_pccommunicator.o(.bss)
MyArray                     0x20003c34   Data           9  fa30_pccommunicator.o(.bss)
.bss                        0x20003c40   Section       96  libspace.o(.bss)
HEAP                        0x20003ca0   Section      512  startup_stm32f10x_xl.o(HEAP)
MyArray[8]
l_fpComShtRcvStsRepOptSkt   0x20000224   Data           4  fa30_pccommunicator.o(.data)
MyArray                     0x20000228   Data           8  fa30_pccommunicator.o(.data)
.data                       0x20000230   Section      351  fa40_comsheet.o(.data)
so there definitely seems to be a difference in interpretation as with the faulty [8] no '.bss' is used which according Wikipedia has to too with static declarations.
Who can help me out?
Thanks,
Henk
